EZVIZ C3W Smart Outdoor Camera, With Siren & Strobe Light
Quicklinx: F8Z6WS00 Mfr#: CS-CV310-A0-1B2WFR
  • microSDHC Card
  • microSD Card
Introducing the EZVIZ Full HD Wi-Fi Outdoor Camera
This wall-mounted outdoor Wi-Fi camera uses a built-in strobe light and 100db alarm for aiding deterrence, whilst also offering two-way talk and durability in any type of weather.
Be Informed
Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are. Great for outdoor detections in the Garden or Driveway.
Reliable Connectivity
Dual antennas on the camera ensure reliable wireless transmission indoors or outdoors, to enhance the connection to and from your Wi-Fi Router, removing potential video lagging whilst maintaining good performance through the various weather conditions when placed outside.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
24/7 All Season Protection
Because of its IP66 enclosure rating, the Outdoor camera will be resistant against rain, snow, and other weather conditions. With the integration of Infrared technology, footage can be seen clearly at Night too.
Two-way Talk
Integrated with professional de-noising algorithm to filter background noise for enhanced voice quality. The internal waterproof MIC supports audio pickup within five meters and video recording with sound via the EZVIZ app.
Easy Setup
Straight Forward installation with drill template included in the box. The camera itself has a Cardan shaft rotation for various angles, great for both ceiling and wall-mounted installation. For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local continuous storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
What’s in the box
  • 1x EZVIZ Full HD Wi-Fi Outdoor Smart Home Security Camera
  • 1x Power Adapter with 7.5 Meters total Power Cable
  • 1x Mounting/Drill Template
  • 1x Screw Kit
  • 1x Waterproof Kit
  • 1x Quick Start Guide
EZVIZ ezGuard Plus CS-CV310-A0-1B2WFR - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - splash-resistant
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Surface mount
7.164 cm x 7.164 cm x 15.044 cm
326 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.7"
Minimum Illumination
0.02 lux F2.0 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.2
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 12 V
Backlight Compensation (BLC), progressive scanning, saturation control, brightness control, contrast control, image mirror, automatic electronic shutter, Intelligent Motion Detection (IMD), infrared cut filter, Digital Wide Dynamic Range (D-WDR), Wi-Fi Protected Setup (WPS), dual video stream, password protection, built-in siren, 3D Digital Noise Reduction Technology, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, bit rate control, built-in strobe light
1-year warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Surface mount
Wired, wireless
7.164 cm
7.164 cm
15.044 cm
326 g
Camera
Colour - Day&Night - fixed - outdoor, indoor - splash-resistant
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
30.5 m
Frame Rate (max)
Image Sensor
CMOS 1/2.7"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.2
Horizontal Field of View (degree)
103
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
IP66
Power Requirements
DC 12 V
Power adapter - external 6 Watt
Limited warranty - parts and labour - 1 year
-30 °C
60 °C
Relative Humidity (operating)
