Ezviz C3TN Smart Bullet Camera
Quicklinx: H0VXWS00 Mfr#: CS-C3TN-A0-1H2WFL
  • microSDHC Card
  • microSD Card
The C3TN Color covers almost every essential function you could ask for a home security camera. 1080p video quality, color night vision, active defense, IP67 weatherproof design and more, are all packaged in one, simple device. Live safer and smarter with the easy control and reliable performance that the C3TN Color offers.
  • Vivid images, from day to night
    Enjoy great 1080p video quality to see details clearly. With two built-in spotlights, the C3TN Color can illuminate the surroundings at night to capture activities in vivid color.
  • Far-reaching night vision for wider protection
    The camera makes sure that no one can easily sneak in under the cover of darkness. It renders color night vision up to 15 meters and infrared black-and-white vision up to 30 meters.
  • Stands up to even extreme weather
    With an IP67-rated camera body, the C3TN Color is both dust- and water-resistant. It can stand steady even against the toughest weather conditions - whether it's rainy, stormy or snowy.
  • Keeps you in the know
    Want to know what's happening when you're not at home? Watch the live stream with a simple tap on your smartphone using the EZVIZ App. What's better, you will receive a mobile alert as soon as the camera detects motion.
  • It's your eyes - and ears
    The C3TN Color comes with a built-in noise-canceling microphone, which can pick up clear audio in the surrounding area. You can see and hear what's going on in your backyard or at your front door at any time.
EZVIZ C3TN - network surveillance camera - bullet
Network surveillance camera - fixed - bullet - weatherproof
Audio
Yes: built-in microphone
7.2 cm x 15.2 cm x 7.2 cm
256 g
White
Wireless, wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
PS CMOS - 1/2.7"
Minimum Illumination
0.01 lux F2.0 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V
Colour Night Vision, strobe light alarm, cloud recording, noise-cancellation, self-adaptive shutter, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), Adaptive Bitrate (ABR), anti-flicker, dual video stream, heartbeat, image mirror, password protection, watermark, 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK
Environmental Parameters (operating)
-20 °C - 50 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Bullet
Wireless, wired
7.2 cm
15.2 cm
7.2 cm
256 g
Camera
Colour - Day&Night - fixed - weatherproof
Digital Video Format
H.264, H.265
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
30 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
PS CMOS 1/2.7"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
106
Diagonal Field of View (degree)
122
Network Interface
Network Protocols
TLS
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Screw kit, waterproof kit, mounting template
IP67, AES-128, TLS, UL, FCC, WEEE, REACH, RoHS, UKCA
White
Power Requirements
DC 12 V - 1 A
Power adapter - external 6 Watt
Internet of Things (IoT)
Supported Host Device Platform
Android, iOS
Shipping Width
22.7 cm
Shipping Depth
10 cm
Shipping Height
9.2 cm
Shipping Weight
500 g
-20 °C
50 °C
Relative Humidity (operating)
