Ezviz BC1 Battery Camera Duo Pack
Quicklinx: H0W6WS00 Mfr#: CS-BC1-B2
The BC1 wire-free camera delivers well-rounded home protection for up to a full year on one single charge. The BC1 inherits EZVIZ's core technologies of color night vision, two-way talk, active defense, and more, showcasing unparalleled usability in any household.
  • Year-long protection on a single charge
    Equipped with an impressive rechargeable battery, the BC1 can last for up to a year on one full battery charge.
  • Vivid night vision
    Thanks to two built-in spotlights, the BC1 can render vivid color imaging even in pitch-black darkness. This allows you to see crucial details that would otherwise be lost.
  • Motion alerts are more accurate
    Integrating a PIR sensor and the person-shape detection algorithm, the BC1 camera is intelligent enough to distinguish persons from other moving objects, keeping you safe while also reducing unwanted notifications.
  • A vigilant guard over your property
    Users can set specific time frames for detection. Once the camera detects a person-shape, the BC1 will automatically set off a siren and flash two spotlights to let them know they have been detected.
  • Customizable voice messages
    A thoughtful product by design, the BC1 allows you to create unique voice messages for greeting or deterrence.
  • Fast and easy wire-free setup
    Featuring a large battery, Wi-Fi connectivity, and a magnetic base, the BC1 camera requires exactly zero professional help in installation. Simply attach the camera to any metallic surface and it is good to go!
  • Built to last
    The BC1 camera features an IP66 enclosure, offering high levels of protection against dust and water and delivering long-lasting protection in even tougher weather conditions.
  • Helps you save money on storage and bandwidth
    The BC1 camera features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space required by the previous H.264 video compression standard.
EZVIZ BC1-B2 - NVR + camera(s) - wireless (802.11b, 802.11g, 802.11n) - battery powered, AC powered
System
NVR + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 2.4 GHz - battery, power adapter
Camera
2 cameras - night vision
Lens Mount
M12 mount
6.28 cm x 10.476 cm x 6.28 cm
1.304 kg
1 year
System
Network Interface
Wireless Frequency Band
2.4 GHz
Built-in microphone, motion alerts, infrared cut filter, dustproof, waterproof, 2-way audio, built-in speaker
Package Content
NVR, 2 cameras, 2 magnetic bases, 2 screw bases, camera power adapter, NVR power adapter, 2 mounting plates, 2 drill templates, 2 screw kits
Software Included (Y)
EZVIZ App
Power Source
Battery, power adapter
Warranty
1 year
Security DVR
Frame Rate (Record)
25 fps, 30 fps
Image Resolution
1920x1080
Compression Format
H.265
Record Events
Motion detection
microSD card slot, smartphone support
Cameras
Quantity
2 cameras
Sensor
CMOS - 1/2.8" - 1920x1080
Field of View
108° (H), 128° (D)
Night Vision
Infrared Distance
10 m
Focal Length
2.8 mm
Lens Mount
M12 mount
Voltage
DC 5 V
Power Consumption
5 Watt
-20 °C
45 °C
Operating Humidity
0-95% (non-condensing)
IP66
Other Ports
RJ-45
6.28 cm
10.476 cm
6.28 cm
1.304 kg
Details
NVR: 8.197 cm x 8.197 cm x 16.022 cm , Camera: 6.28 cm x 10.476 cm x 6.28 cm
