The highly popular Evoluent mouse just got better! Introducing the all new Evoluent 4. Building on the reputation of Evoluent 3, this mouse has new features to improve the comfort and ease of use. Wireless connection.
Comfortable and easy to use
Thoughtfully sculpted for uncompromised comfort and easy-to-reach programmable buttons. No finger contortions are needed. -
Adjustable laser sensor
Pointer speed buttons on the side allow convenient adjustment without even changing your grip on the mouse. -
Pointer speed indicators
Top mounted LEDs show through the chrome thumb rest to indicate selected pointer speed from extra low to high. -
Lighted Evoluent logo
Pure eye candy. The illumination turns off when the system is in sleep mode to conserve notebook battery power. -
Useful and intuitive driver
Mouse manager for Windows provides extensive but easy to use functionality through a simple and intuitive interface.
- Evoluent VerticalMouse 4 - vertical mouse - 2.4 GHz
- Vertical mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Orientation
- Right-handed
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 6
- Programmable buttons, scrolling wheel, sensitivity adjustment, battery indicator, resolution indicator
- Battery
- AA type
- OS Required
- UNIX, Apple MacOS, Linux, Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- Vertical mouse
- Wireless Receiver
- Orientation
- Right-handed
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- Buttons Qty
- 6
- 1 x USB - 4 pin USB Type A
- AA type
- OS Required
