Evoluent VerticalMouse 4 Right Hand Wireless Black
Quicklinx: BRCCWS00 Mfr#: M-EVOL-S4W
Type: Mouse
Wired / Wireless: Wireless
Compatibility: Mac, PC
£95.58 ex VAT
£114.69 inc VAT
The highly popular Evoluent mouse just got better! Introducing the all new Evoluent 4. Building on the reputation of Evoluent 3, this mouse has new features to improve the comfort and ease of use. Wireless connection.
  • Comfortable and easy to use
    Thoughtfully sculpted for uncompromised comfort and easy-to-reach programmable buttons. No finger contortions are needed.
  • Adjustable laser sensor
    Pointer speed buttons on the side allow convenient adjustment without even changing your grip on the mouse.
  • Pointer speed indicators
    Top mounted LEDs show through the chrome thumb rest to indicate selected pointer speed from extra low to high.
  • Lighted Evoluent logo
    Pure eye candy. The illumination turns off when the system is in sleep mode to conserve notebook battery power.
  • Useful and intuitive driver
    Mouse manager for Windows provides extensive but easy to use functionality through a simple and intuitive interface.
Evoluent VerticalMouse 4 - vertical mouse - 2.4 GHz
Vertical mouse
Wireless - 2.4 GHz
Orientation
Right-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
6
Programmable buttons, scrolling wheel, sensitivity adjustment, battery indicator, resolution indicator
AA type
UNIX, Apple MacOS, Linux, Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
Vertical mouse
Wireless Receiver
Orientation
Right-handed
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
6
1 x USB - 4 pin USB Type A
AA type
Type: Mouse
Compatibility: Mac
Compatibility: PC
Brand: Evoluent
