Evoluent VerticalMouse 4 - Mouse
Quicklinx: 91BTWS00 Mfr#: VM4L
£79.94 ex VAT
£95.92 inc VAT
The patented shape supports your hand in an upright neutral posture that generally avoids forearm twisting. Many users, including medical doctors, ergonomists and physical therapists, said the Evoluent VerticalMouse provides superior comfort and even relieved their wrist pain.
  • Comfortable and easy to use
    The shape is thoughtfully sculpted for uncompromised comfort and easy-to-reach programmable buttons. No finger contortions are needed to operate the buttons.
  • Adjustable laser sensor
    Pointer speed controls on the side allow convenient adjustment without even releasing your grip from the mouse.
  • Improved thumb rest
    The thumb rest has been reshaped to provide even more comfort over earlier versions.
  • Pointer speed indicators
    Top mounted LEDs show through the chrome thumb rest to indicate selected pointer speed including extra low (XL), low (LO), MD (medium), to high (HI).
  • Two thumb buttons
    A new bottom thumb button provides greatly extended functionality when used with the included driver.
  • Extended lip prevents rubbing
    An extra wide lip along the bottom edge prevents the last finger from rubbing the desk.
Evoluent VerticalMouse 4 Left - vertical mouse - USB - grey, silver
Vertical mouse - ergonomic
Wired - USB
Grey, silver
Orientation
Left-handed
8.9 cm x 11.1 cm x 8 cm
135 g
Movement Detection Technology
Laser
Buttons Qty
6
Scrolling wheel, Pointer speed indicators, 6 programmable buttons, blue lighted logo, thumb rest, adjustable optical sensor, Finger Flange
Linux, Apple MacOS X or later, Microsoft Windows XP / 7 / 8 / 10
Vertical mouse
Ergonomic Design
Orientation
Left-handed
8.9 cm
11.1 cm
8 cm
135 g
Grey, silver
Input Device
Wired
USB
Laser
Buttons Qty
6
1 x USB - 4 pin USB Type A
