Evoluent Vertical Mouse 4 – Wired –Right Handed
Quicklinx: BZ67WS00 Mfr#: KBC-EVM004R
Type: Mouse
Wired / Wireless: Wired
Compatibility: PC, Mac
£121.88 ex VAT
£146.25 inc VAT
The patented shape of the mouse supports your hand in an upright neutral posture that generally avoids forearm twisting. Many users, including medical doctors, ergonomists and physical therapists, said the Evoluent VerticalMouse provides superior comfort and even relieved their wrist pain.
  • Comfortable and easy to use
    The shape is thoughtfully sculpted for uncompromised comfort and easy-to-reach programmable buttons. No finger contortions are needed to operate the buttons.
  • Adjustable laser sensor
    Pointer speed controls on the side allow convenient adjustment without even releasing your grip from the mouse.
  • Improved thumb rest
    The thumb rest has been reshaped to provide even more comfort over earlier versions.
  • Pointer speed indicators
    Top mounted LEDs show through the chrome thumb rest to indicate selected pointer speed including extra low (XL), low (LO), MD (medium), to high (HI).
  • Now two thumb buttons
    A bottom thumb button provides greatly extended functionality when used with the included driver.
  • Lighted Evoluent logo
    The logo is pure eye candy. The illumination turns off when the system is in sleep mode to conserve notebook battery power.
  • Extended lip prevents rubbing
    An extra wide lip along the bottom edge prevents the last finger from rubbing the desk.
  • Powerful and intuitive driver
    Evoluent mouse manager for Windows provides extensive but easy to use functionality for 6 buttons through a simple and intuitive interface.
Evoluent VerticalMouse 4 Right - vertical mouse - USB
Vertical mouse
Wired - USB
Orientation
Right-handed
11.1 cm x 8.7 cm x 8 cm
170 g
Movement Detection Technology
Laser
Buttons Qty
6
Scrolling wheel
Linux, Apple MacOS X or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Vertical mouse
Orientation
Right-handed
11.1 cm
8.7 cm
8 cm
170 g
Input Device
Wired
USB
Laser
Buttons Qty
6
Scrolling wheel
1 x USB - 4 pin USB Type A
Type: Mouse
Compatibility: PC
Compatibility: Mac
Brand: Evoluent
