All 5 buttons are easily operable without contorting your fingers. The button force is light for easy clicking, but still firm enough to avoid accidental actuation. A small lip on the bottom edge prevents the little finger from rubbing the desk.
Eliminates arm twisting
The shape supports your hand in a fully upright handshake position that eliminates forearm twisting. -
Familiar grip
The grip is the same as an ordinary mouse, just turned sideways into a handshake position. Many users said they got used to it very quickly. -
Easy to use buttons
All 5 buttons are easily operable without contorting your fingers. The button force is light for easy clicking, but still firm enough to avoid accidental actuation. -
Prevents desk rubbing
- Evoluent VerticalMouse 3 Right - vertical mouse - USB
- Vertical mouse
- Connectivity Technology
- Wired - USB
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Orientation
- Right-handed
- 8 cm x 11.3 cm x 7.7 cm
- 189 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 2600 dpi
- Programmable buttons, scrolling wheel, Click lock, Auto click
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Vertical mouse
- Orientation
- Right-handed
- 8 cm
- 11.3 cm
- 7.7 cm
- 189 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 5
- 2600 dpi
- 1 x USB - 4 pin USB Type A
- Cables Included
- OS Required
