Evoluent Hypertec Evoluent Vertical Mouse 3
Quicklinx: 93HXWS00 Mfr#: VM3R
Type: Mouse
Wired / Wireless: Wired
Compatibility: Mac, PC
£58.99 ex VAT
£70.78 inc VAT
All 5 buttons are easily operable without contorting your fingers. The button force is light for easy clicking, but still firm enough to avoid accidental actuation. A small lip on the bottom edge prevents the little finger from rubbing the desk.
  • Eliminates arm twisting
    The shape supports your hand in a fully upright handshake position that eliminates forearm twisting.
  • Familiar grip
    The grip is the same as an ordinary mouse, just turned sideways into a handshake position. Many users said they got used to it very quickly.
  • Easy to use buttons
  • Prevents desk rubbing
Evoluent VerticalMouse 3 Right - vertical mouse - USB
Vertical mouse
Wired - USB
Image Colour Disclaimer
The displayed product image may be a different colour
Orientation
Right-handed
8 cm x 11.3 cm x 7.7 cm
189 g
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
2600 dpi
Programmable buttons, scrolling wheel, Click lock, Auto click
1 x USB cable - integrated
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Vertical mouse
Orientation
Right-handed
8 cm
11.3 cm
7.7 cm
189 g
Input Device
Wired
USB
Optical
Buttons Qty
5
Movement Resolution
2600 dpi
1 x USB - 4 pin USB Type A
Type: Mouse
Compatibility: Mac
Compatibility: PC
Brand: Evoluent
