EVGA's PD03 is the right solution for any user looking to gain the best experience a zero client can offer. The EVGA PD03 is "a true zero client" providing the user with a small foot print design, low power consumption, centralized virus protection, OS versatility and full USB support.
Centralized computing is now a truly viable option for all user types, either locally via LAN or remotely via WAN. PCoIP broadcasts only the encrypted pixels not the data across the network to the client. This makes it possible for a stateless, decode only device, a true zero client.
- EVGA PD03 - USFF Tera1100 - 128 MB
- Zero client - ultra small form factor - PC over IP (PCoIP) technology
- Processor
- 1 x Teradici Tera1100
- RAM
- 128 MB XDRAM
- Optical Storage
- No optical drive
- Audio Output
- Stereo - integrated
- Networking
- GigE
- OS Provided
- No operating system
- Software Included
- Drivers & Utilities
- 11.9 cm x 12.95 cm x 6.1 cm
- Limited warranty - 3 years
- Zero client
- Product Form Factor
- Ultra small form factor
Processor / Chipset
- CPU
- Teradici Tera1100
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 128 MB
- Technology
- XDRAM
- Effective Memory Speed
- 400 MHz
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Integrated
- Data Link Protocol
- Slots
- Memory , 1 (total) / 0 (free) x CPU
- 4 x USB 2.0 (2 front, 2 rear) , 2 x DVI-I , 1 x microphone , 1 x audio line-out/headphones , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- UL, TUV, C-Tick, cUL, FCC, RoHS
- Power adapter
- 12 Watt
Operating System / Software
- OS Provided
- Software
- 11.9 cm
- 12.95 cm
- 6.1 cm
- 5 °C
- 40 °C
- 20 - 80%
EVGA PD03 PCoIP Zero Client 128MB XDR
