EVGA NVIDIA GeForce GTX 1070 FTW GAMING ACX3.0 8GB GDDR5 PCIe3.0
Quicklinx: CBHBWS00 Mfr#: 08G-P4-6276-KR
The EVGA GeForce GTX 1070 featuring EVGA ACX 3.0 cooling is here. This graphics card features NVIDIA's "Pascal" graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative gaming technologies, and immersive, next-gen VR.
These cards also feature EVGA ACX 3.0 cooling technology. EVGA ACX 3.0 once again brings great and exciting features to the award winning EVGA ACX cooling technology. SHP 3.0 gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX 3.0 coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU. Select EVGA ACX 3.0 models will even feature a 10CM fan and RGB LED, allowing complete control over the color from EVGA Precision XOC.
EVGA GeForce GTX 1070 FTW Gaming ACX 3.0 - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
8 GB GDDR5
Core Clock
1607 MHz
Boost Clock
1797 MHz
CUDA Cores
1920
Effective Memory Clock
8008 MHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
26.67 cm x 13.7743 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1797 MHz
CUDA Cores
1920
VR Ready
Max Resolution
7680 x 4320
4
API Supported
Dual Slot Fan Cooler, Dual Bios, Nvidia SLI ready, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, 4+1 Phase Power Design, GameWorks, eVGA Active Cooling Xtreme (ACX) 3.0
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8008 MHz
Bus Width
256-bit
Bandwidth
256.3 GBps
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Required Power Supply
500 W
Additional Requirements
2 x 8 pin PCI Express power connector
215 Watt
26.67 cm
13.7743 cm
Limited warranty - 3 years
