EVGA NVIDIA GeForce GTX 1050 SC GAMING 2GB GDDR5 Graphics Card
Quicklinx: D3D0WS00 Mfr#: 02G-P4-6152-KR
he EVGA GeForce GTX 1050 Ti hits the perfect spot for that upgrade you know you need, but at the price you want! With the latest NVIDIA Pascal architecture, the 4GB GTX 1050 Ti displays stunning visuals and great performance at 1080p HD+.
Installing a EVGA GeForce GTX 1050 Ti gives you the power to take on today next-gen titles in Full 1080p HD with room to spare. These cards give you a choice of memory sizes, cooling options, factory overclocks, and power options to fit every need and every system. Of course, no GTX card would be complete without essential gaming technologies, such as NVIDIA GameStream, G-Sync, and GeForce Experience.
If you've been waiting for that card that gives you the performance to take back the competitive edge, but without taking out your wallet, then the GTX 1050 Ti is the card for you!
EVGA GeForce GTX 1050 SC Gaming - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1417 MHz
Boost Clock
1531 MHz
CUDA Cores
640
Effective Memory Clock
7008 MHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
3
Interfaces Details
DisplayPort , DVI-D (dual link) , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
14.478 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1417 MHz
Boost Clock
1531 MHz
CUDA Cores
640
Max Resolution
7680 x 4320
3
Interfaces Details
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7008 MHz
Bus Width
128-bit
Bandwidth
112.16 GBps
Microsoft Windows 7 / 8 / 10 (32/64 bits)
Required Power Supply
300 W
75 watt
Software Included
EVGA Precision X OC
14.478 cm
11.115 cm
Limited warranty - 3 years
