EVGA GeForce GTX 970 4GB PCI-Express 3.0 HDMI SSC with ACX Cooling 2.0+
Quicklinx: B2D2WS00 Mfr#: 04G-P4-3975-KR
  • NVIDIA GeForce GTX 970
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
The EVGA GeForce GTX 970 offers improved cooling, double BIOS support, great display output configuration and 6 power phases for robust overclocking support. The EVGA ACX 2.0+ cooler brings additional features to the cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET and Memory temperatures, and optimized Straight Heat Pipes (SHP) reduce GPU temperature. ACX 2.0+ coolers also feature optimized Swept fan blades, double ball bearings and an extreme low power motor, delivering more airflow with less power, unlocking additional power for the GPU.
  • NVIDIA Dynamic Super Resolution technology
    This feature can deliver 4K fidelity to 1080p displays for exceptional detail and image quality.
  • NVIDIA MFAA technology
    MFAA delivers a huge performance boost while maintaining smooth, high-quality edges by alternativing sample calculations across each frame and each pixel.
  • NVIDIA GameWorks technology
    NVIDIA GameWorks pushes the limits for gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games.
  • HDMI 2.0, DisplayPort 1.2 and Dual-link DVI
    Supporting up to four concurrent monitors.
  • NVIDIA GameStream technology
    Stream extreme GeForce GTX PC gaming experiences to portable device like NVIDIA SHIELD with super-smooth, low-latency performance.
  • PCI Express 3.0
    This card is designed for the PCI Express 3.0 bus architecture, offering the highest data transfer speeds for extremely bandwidth-hungry games and 3D applications. It also maintains backwards compatibility with existing PCI Express motherboards for the broadest support.
  • NVIDIA G-SYNC ready
    NVIDIA G-SYNC monitors feature the incredible NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is the smoothest, fastest, and very responsive gaming experience ever seen.
  • EVGA ACX 2.0 cooling
    With optimized Swept fan blades, double ball bearings and an extreme low power motor, EVGA ACX 2.0 delivers more air flow with less power, unlocking additional power for the GPU.
  • Quick switch dual BIOS
    Two separate BIOS's that you can switch with the flick of a switch.
  • NVIDIA GPU boost 2.0
    Dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. This allows gamers to push performance to extreme levels.
  • NVIDIA Adaptive Vertical Sync
    Dynamically enable vertical sync based on your current frame rates for the smoothest gaming experience.
  • NVIDIA Surround technology
    With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. Add in a fourth accessory display to get access to your email, web, or other applications while you game.
  • Memory MOSFET cooling plate
    Full size cooling base plate makes contact with GPU memory and MOSFETs, reducing temperature.
  • NVIDIA SLI ready
    Industry leading NVIDIA SLI technology offers amazing performance scaling by implementing AFR (Alternate Frame Rendering) for the world's premier gaming solution with solid, state-of-the-art drivers.
  • Optimized power target
    The power target is precisely tuned for the perfect balance of thermal, power and performance.
EVGA GeForce GTX 970 SSC ACX 2.0+ - graphics card - GF GTX 970 - 4 GB - black
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 970 - up to
4 GB GDDR5
Core Clock
1190 MHz
Boost Clock
1342 MHz
CUDA Cores
1664
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I , 3 x DisplayPort , HDMI
25.65 cm x 11.115 cm
Enclosure Colour
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1190 MHz
Boost Clock
1342 MHz
CUDA Cores
1664
Max Resolution
4096 x 2160 at 240 Hz
4
Interfaces Details
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Bandwidth
224.3 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Required Power Supply
500 W
6 pin PCIe power cable, 8-pin PCIe to Molex power adapter
25.65 cm
11.115 cm
Enclosure Colour
Limited warranty - 3 years
