EVGA GeForce GTX 750 Ti 1020MHz 2GB PCI-E 3.0 HDMI
Quicklinx: 98FFWS00 Mfr#: 02G-P4-3751-KR
  • NVIDIA GeForce GTX 750 Ti
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
If you're looking for hyper-realistic gameplay, stunning visuals, and exceptional value, this is your graphics card.
SPECIFICATIONS
  • Base Clock: 1020 MHz
  • Boost Clock: 1085 MHz
  • Memory Clock: 5400 MHz Effective
  • CUDA Cores: 640
  • Bus Type: PCI-E 3.0
  • Memory Detail: 2048MB GDDR5
  • Memory Bit Width: 128 Bit
  • Memory Speed: 0.4ns
  • Memory Bandwidth: 86.4 GB/s
KEY FEATURES
  • NVIDIA® TXAA™ Technology
  • NVIDIA GPU Boost 2.0
  • NVIDIA® PhysX® Technology
  • NVIDIA FXAA™ Technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA® Surround™
  • Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
  • Microsoft® DirectX® 11.2 API (feature level 11_0) with Direct Compute 5.0 support
  • NVIDIA 3D Vision®-Ready*
  • NVIDIA CUDA® Technology
  • PCI Express® 3.0 Support
  • OpenGL 4.4 Support
  • OpenCL™ Support
  • NVIDIA SHIELD™-Ready
  • NVIDIA G-SYNC™-Ready
REQUIREMENTS
  • 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
  • PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
  • Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
  • Height: 4.376in - 111.15mm
  • Length: 6.7in - 170.18mm
  • Weight: 0.85lbs
ACCESSORIES
  • EVGA Driver/Software Disc
  • (1) DVI to VGA Adapter
  • EVGA Accessory Pack
  • User Guide
EVGA GeForce GTX 750 Ti - graphics card - GF GTX 750 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1020 MHz
Boost Clock
1085 MHz
CUDA Cores
640
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
17.018 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1020 MHz
Boost Clock
1085 MHz
CUDA Cores
640
Max Resolution
4096 x 2160
API Supported
Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Bandwidth
86.4 GBps
Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Required Power Supply
400 W
Additional Requirements
Adjacent PCI slot
60 Watt
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
RoHS
17.018 cm
11.115 cm
Limited warranty - parts and labour - 3 years
Resources
The following resources are available for the EVGA GeForce GTX 750 Ti 1020MHz 2GB PCI-E 3.0 HDMI
