EVGA GeForce GTX 750 1GB PCI-Express 3.0 HDMI FTW w/ ACX
Quicklinx: 9HTBWS00 Mfr#: 01G-P4-2757-KR
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Step up to EVGA GeForce GTX gaming with the GTX 750. Its powerful, ultra-efficient architecture makes the GTX 750 the weapon of choice for serious gaming at an incredible value.
GTX 750 card gives you the gaming horsepower to take on today's most demanding titles in full 1080p HD. It delivers 25% more performance than previous-generation cards and up to twice the power efficiency, thanks to the NVIDIA Maxwell architecture. Plus, it comes loaded with GeForce GTX gaming technologies like NVIDIA GameStream, G-Sync and GeForce Experience.
If you're looking for hyper-realistic gameplay, stunning visuals and exceptional value, this is your graphics card!
  • NVIDIA PhysX technology
    Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
  • PCI Express 3.0 support
    Designed for the new PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
  • NVIDIA SMX engine
    Streaming multiprocessor built from the ground up for incredible performance and power efficiency.
  • OpenGL 4.4 support
    Supporting the standards in the OpenGL API.
  • NVIDIA GPU Boost
    Dynamically maximizes clock speeds based on workload of the game to push performance to new levels and bring out the best in every game.
  • OpenCL support
    Supporting the standards in GPGPU computing.
  • NVIDIA adaptive vertical sync
    Dynamically enables vertical sync based on your current frame rates for the smooth gaming experience.
  • NVIDIA FXAA technology
    Shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games.
  • NVIDIA surround
    With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience.
  • NVIDIA TXAA technology
    Support for temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance.
  • Microsoft DirectX 11.2 API with Direct Compute 5.0 support
    DirectX 11.2 API GPU with Shader Model 5.0 support designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation.
  • NVIDIA PureVideo HD technology
    The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
  • NVIDIA 3D Vision ready
    Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC.
  • NVIDIA G-Sync ready
    NVIDIA G-Sync is a technology that eliminates screen tearing, VSync input lag, and stutter. The result is the smoothest, fastest, and most responsive gaming experience ever seen.
  • NVIDIA CUDA technology
    Unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
EVGA GeForce GTX 750 - graphics card - GF GTX 750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750
1 GB GDDR5
Core Clock
1229 MHz
Boost Clock
1320 MHz
CUDA Cores
512
Effective Memory Clock
5.012 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
DVI-I (dual link) , HDMI , DisplayPort
API Supported
OpenCL, OpenGL 4.4, DirectX 12
24.1 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1229 MHz
Boost Clock
1320 MHz
CUDA Cores
512
Max Resolution
4096 x 2160
API Supported
Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, x.v.Color technology, Deep Color technology, Blu-Ray 3D Support, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready, NVIDIA G-Sync ready, Nvidia Temporal Anti-Aliasing Technology (TXAA)
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.012 GHz
Bus Width
128-bit
Bandwidth
80 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Required Power Supply
300 W
Additional Requirements
6 pin PCI Express power connector
80 Watt
Software Included
EVGA Precision X, EVGA OC Scanner X
24.1 cm
11.115 cm
Limited warranty - 3 years
Resources
The following resources are available for the EVGA GeForce GTX 750 1GB PCI-Express 3.0 HDMI FTW w/ ACX
