EVGA GeForce GTX 750 1215MHz 1GB PCI-E 3.0 HDMI SC
Quicklinx: 98FJWS00 Mfr#: 01G-P4-2753-KR
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Step up to GeForce® GTX™ gaming with the new EVGA GTX 750. Its powerful, ultra-efficient next-gen architecture makes the GTX 750 the weapon of choice for serious gaming at an incredible value. Take on today's most demanding titles with 25% more performance and up to twice the power efficiency of previousgeneration cards, plus GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™.
SPECIFICATIONS
  • Base Clock: 1215 MHz
  • Boost Clock: 1294 MHz
  • Memory Clock: 5012 MHz Effective
  • CUDA Cores: 512
  • Bus Type: PCI-E 3.0
  • Memory Detail: 1024MB GDDR5
  • Memory Bit Width: 128 Bit
  • Memory Speed: 0.4ns
  • Memory Bandwidth: 80 GB/s
KEY FEATURES
  • NVIDIA® TXAA™ Technology
  • NVIDIA GPU Boost 2.0
  • NVIDIA® PhysX® Technology
  • NVIDIA FXAA™ Technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA® Surround™
  • Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
  • Microsoft® DirectX® 11.2 API (feature level 11_0) with DirectCompute 5.0 support
  • NVIDIA 3D Vision®-Ready*
  • NVIDIA CUDA® Technology
  • PCI Express® 3.0 Support
  • OpenGL 4.4 Support
  • OpenCL™ Support
  • NVIDIA SHIELD™-Ready
  • NVIDIA G-SYNC™-Ready
REQUIREMENTS
  • 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
  • PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
  • Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
  • Height: 4.376in - 111.15mm
  • Length: 6.7in - 170.18mm
  • Weight: 0.85bs
ACCESSORIES
  • EVGA Driver/Software Disc
  • (1) DVI to VGA Adapter
  • EVGA Accessory Pack
  • User Guide
EVGA GeForce GTX 750 Superclocked - graphics card - GF GTX 750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750
1 GB GDDR5
Core Clock
1215 MHz
Boost Clock
1294 MHz
CUDA Cores
512
Effective Memory Clock
5.012 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Interfaces Details
DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
17.018 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1215 MHz
Boost Clock
1294 MHz
CUDA Cores
512
Max Resolution
4096 x 2160
Interfaces Details
API Supported
Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.012 GHz
Bus Width
128-bit
Bandwidth
80 GBps
Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Required Power Supply
400 W
Additional Requirements
Adjacent PCI slot
55 Watt
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
RoHS
17.018 cm
11.115 cm
Limited warranty - parts and labour - 3 years
Resources
The following resources are available for the EVGA GeForce GTX 750 1215MHz 1GB PCI-E 3.0 HDMI SC
