EVGA GeForce GTX 750 1020MHz 1GB PCI-E 3.0 HDMI
Quicklinx: 98FKWS00 Mfr#: 01G-P4-2751-KR
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Step up to GeForce® GTX™ gaming with the new EVGA GTX 750. Its powerful, ultra-efficient next-gen architecture makes the GTX 750 the weapon of choice for serious gaming at an incredible value. Take on today's most demanding titles with 25% more performance and up to twice the power efficiency of previousgeneration cards, plus GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™.
SPECIFICATIONS
  • Base Clock: 1020 MHz
  • Boost Clock: 1085 MHz
  • Memory Clock: 5012 MHz Effective
  • CUDA Cores: 512
  • Bus Type: PCI-E 3.0
  • Memory Detail: 1024MB GDDR5
  • Memory Bit Width: 128 Bit
  • Memory Speed: 0.4ns
  • Memory Bandwidth: 80 GB/s
KEY FEATURES
  • NVIDIA® TXAA™ Technology
  • NVIDIA GPU Boost 2.0
  • NVIDIA® PhysX® Technology
  • NVIDIA FXAA™ Technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA® Surround™
  • Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
  • Microsoft® DirectX® 11.2 API (feature level 11_0) with Direct Compute 5.0 support
  • NVIDIA 3D Vision®-Ready*
  • NVIDIA CUDA® Technology
  • PCI Express® 3.0 Support
  • OpenGL 4.4 Support
  • OpenCL™ Support
  • NVIDIA SHIELD™-Ready
  • NVIDIA G-SYNC™-Ready
REQUIREMENTS
  • 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
  • PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
  • Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
  • Height: 4.376in - 111.15mm
  • Length: 6.7in - 170.18mm
  • Weight: 0.85lbs
ACCESSORIES
  • EVGA Driver/Software Disc
  • (1) DVI to VGA Adapter
  • EVGA Accessory Pack
  • User Guide
  • NVIDIA PhysX technology
    Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
  • PCI Express 3.0 support
    Designed for the new PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
  • NVIDIA SMX engine
    Streaming multiprocessor built from the ground up for incredible performance and power efficiency.
  • OpenGL 4.4 support
    Supporting the standards in the OpenGL API.
  • NVIDIA GPU Boost
    Dynamically maximizes clock speeds based on workload of the game to push performance to new levels and bring out the best in every game.
  • OpenCL support
    Supporting the standards in GPGPU computing.
  • NVIDIA adaptive vertical sync
    Dynamically enables vertical sync based on your current frame rates for the smooth gaming experience.
  • NVIDIA FXAA technology
    Shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games.
  • NVIDIA surround
    With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience.
  • NVIDIA TXAA technology
    Support for temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance.
  • Microsoft DirectX 11.2 API with Direct Compute 5.0 support
    DirectX 11.2 API GPU with Shader Model 5.0 support designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation.
  • NVIDIA PureVideo HD technology
    The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
  • NVIDIA 3D Vision ready
    Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC.
  • NVIDIA G-Sync ready
    NVIDIA G-Sync is a technology that eliminates screen tearing, VSync input lag, and stutter. The result is the smoothest, fastest, and most responsive gaming experience ever seen.
  • NVIDIA CUDA technology
    Unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
EVGA GeForce GTX 750 - graphics card - GF GTX 750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750
1 GB GDDR5
Core Clock
1020 MHz
Boost Clock
1085 MHz
CUDA Cores
512
Effective Memory Clock
5.012 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
17.018 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1020 MHz
Boost Clock
1085 MHz
CUDA Cores
512
Max Resolution
4096 x 2160
API Supported
Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.012 GHz
Bus Width
128-bit
Bandwidth
80 GBps
Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Required Power Supply
400 W
Additional Requirements
Adjacent PCI slot
55 Watt
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
RoHS
17.018 cm
11.115 cm
Limited warranty - parts and labour - 3 years
Resources
The following resources are available for the EVGA GeForce GTX 750 1020MHz 1GB PCI-E 3.0 HDMI
