Step up to GeForce® GTX™ gaming with the new EVGA GTX 750. Its powerful, ultra-efficient next-gen architecture makes the GTX 750 the weapon of choice for serious gaming at an incredible value. Take on today's most demanding titles with 25% more performance and up to twice the power efficiency of previousgeneration cards, plus GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™.
SPECIFICATIONS
- Base Clock: 1020 MHz
- Boost Clock: 1085 MHz
- Memory Clock: 5012 MHz Effective
- CUDA Cores: 512
- Bus Type: PCI-E 3.0
- Memory Detail: 1024MB GDDR5
- Memory Bit Width: 128 Bit
- Memory Speed: 0.4ns
- Memory Bandwidth: 80 GB/s
KEY FEATURES
- NVIDIA® TXAA™ Technology
- NVIDIA GPU Boost 2.0
- NVIDIA® PhysX® Technology
- NVIDIA FXAA™ Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA® Surround™
- Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
- Microsoft® DirectX® 11.2 API (feature level 11_0) with Direct Compute 5.0 support
- NVIDIA 3D Vision®-Ready*
- NVIDIA CUDA® Technology
- PCI Express® 3.0 Support
- OpenGL 4.4 Support
- OpenCL™ Support
- NVIDIA SHIELD™-Ready
- NVIDIA G-SYNC™-Ready
REQUIREMENTS
- 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
- PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
- Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
- Height: 4.376in - 111.15mm
- Length: 6.7in - 170.18mm
- Weight: 0.85lbs
ACCESSORIES
- EVGA Driver/Software Disc
- (1) DVI to VGA Adapter
- EVGA Accessory Pack
- User Guide
NVIDIA PhysX technology
Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
PCI Express 3.0 support
Designed for the new PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
NVIDIA SMX engine
Streaming multiprocessor built from the ground up for incredible performance and power efficiency. -
OpenGL 4.4 support
Supporting the standards in the OpenGL API. -
NVIDIA GPU Boost
Dynamically maximizes clock speeds based on workload of the game to push performance to new levels and bring out the best in every game. -
OpenCL support
Supporting the standards in GPGPU computing. -
NVIDIA adaptive vertical sync
Dynamically enables vertical sync based on your current frame rates for the smooth gaming experience. -
NVIDIA FXAA technology
Shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. -
NVIDIA surround
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. -
NVIDIA TXAA technology
Support for temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance. -
Microsoft DirectX 11.2 API with Direct Compute 5.0 support
DirectX 11.2 API GPU with Shader Model 5.0 support designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation. -
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video. -
NVIDIA 3D Vision ready
Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. -
NVIDIA G-Sync ready
NVIDIA G-Sync is a technology that eliminates screen tearing, VSync input lag, and stutter. The result is the smoothest, fastest, and most responsive gaming experience ever seen. -
NVIDIA CUDA technology
Unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
- EVGA GeForce GTX 750 - graphics card - GF GTX 750 - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750
- Memory
- 1 GB GDDR5
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- CUDA Cores
- 512
- Effective Memory Clock
- 5.012 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.4
- 17.018 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- CUDA Cores
- 512
- Max Resolution
- 4096 x 2160
- API Supported
- Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.012 GHz
- Bus Width
- 128-bit
- Bandwidth
- 80 GBps
- OS Required
- Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Required Power Supply
- 400 W
- Additional Requirements
- Adjacent PCI slot
- 55 Watt
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
- RoHS
- 17.018 cm
- 11.115 cm
- Limited warranty - parts and labour - 3 years
