EVGA GeForce GT 740 2GB GDDR5 PCI Express 3.0 HDMI FTW
Quicklinx: 9K1RWS00 Mfr#: 02G-P4-3744-KR
  • High-Definition Multimedia Interface (HDMI)
Accelerate your entire PC experience with a EVGA GeForce GT 740 graphics card. Enjoy all your videos and pictures at HD resolutions, with 10x faster video editing, 13x faster photo editing, and 9x faster web browsing compared to integrated graphics. Plus, experience 4x faster gaming performance that makes all your gameplay richer and smoother. You can even tap into GeForce Experience to automatically get the latest drivers and optimize game settings with a single click. The EVGA GeForce GT 740 is everything you love, a whole lot faster.
  • NVIDIA PhysX technology
    Full support for NVIDIA PhysX technology, enabling a totally class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
  • NVIDIA SMX Engine
    Next generation streaming multiprocessor built from the ground up for incredible performance and power efficiency.
  • NVIDIA Adaptive Vertical Sync
    It dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
  • NVIDIA Surround
    With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. NVIDIA Surround also supports triple screen gaming with non-3D Vision monitors. Add in a fourth accessory display to get access to your email, web, or other applications while you game.
  • NVIDIA 3D Vision Ready
    Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D.
  • NVIDIA CUDA technology
    It unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
  • PCI Express 3.0 support
    Designed for the PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
  • NVIDIA FXAA technology
    Shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games.
  • NVIDIA TXAA technology
    Support for temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance.
  • NVIDIA PureVideo HD technology
    The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
EVGA GeForce GTX 740 FTW - graphics card - GF GT 740 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GT 740
2 GB GDDR5
Core Clock
1202 MHz
CUDA Cores
384
Effective Memory Clock
5 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
HDMI: 4096 x 2160 / VGA: 2048 x 1536
DVI-I , DVI-D , Mini-HDMI , VGA - with adapter
API Supported
OpenCL, OpenGL 4.4, DirectX 12
15.24 cm x 11.115 cm
3-year warranty with product registration
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1202 MHz
CUDA Cores
384
Max Resolution
4096 x 2160 at 240 Hz
API Supported
Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia Surround technology, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
128-bit
Bandwidth
80 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
64 Watt
6 pin power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
15.24 cm
11.115 cm
Limited warranty - parts and labour - 3 years
