EVGA GeForce GT 720 797MHz 2GB PCI-Express 2.0 HDMI
Quicklinx: 9Q05WS00 Mfr#: 02G-P3-2724-KR
  • High-Definition Multimedia Interface (HDMI)
Make your entire PC experience faster with the new NVIDIA® GeForce® GT 720 dedicated graphics card. Enjoy performance that's superior to integrated graphics in all your PC multimedia applications, including 2x faster web browsing, 5x faster video editing, and 8x faster photo editing.
Play modern games with advanced and reliable dedicated graphics. 70% faster performance than integrated graphics means a rich and smooth gaming experience. Plus, get the power to drive up to three HD displays with a single card.
GeForce GT means speed, stability, and industry-leading NVIDIA drivers. Tap into GeForce Experience™ to automatically get the latest drivers and optimize game settings with a single click.
SPECIFICATIONS
  • Base Clock: 797 MHZ
  • Memory Clock: 1800 MHz Effective
  • CUDA Cores: 192
  • Bus Type: PCI-E 2.0
  • Memory Detail: 2048MB DDR3
  • Memory Bit Width: 64 Bit
  • Memory Speed: 1.43ns
  • Memory Bandwidth: 14.4 GB/s
DIMENSIONS
  • Height: 2.709in - 68.8mm
  • Length: 6.6in - 167.75mm
KEY FEATURES
  • NVIDIA PhysX technology
  • PCI Express 2.0 support
  • NVIDIA Adaptive Vertical Sync
  • Microsoft DirectX 12 API (feature level 11_0) Support
  • NVIDIA 3D Vision Ready*
  • NVIDIA CUDA Technology
  • OpenGL 4.4 Support
  • OpenCL Support
  • NVIDIA FXAA Technology
  • NVIDIA PureVideo HD Technology
REQUIREMENTS
  • 300 Watt or greater power supply with a minimum of 20 Amp on the +12 volt rail.**
  • PCI Express, PCI Express 2.0 or PCI Express 3.0 compliant motherboard with one graphics slot.
  • Windows 8 32/64bit, Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
EVGA GeForce GT 720 - graphics card - GF GT 720 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 720
2 GB DDR3
Core Clock
797 MHz
CUDA Cores
192
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
3
VGA , DVI-D (dual link) , HDMI
API Supported
OpenCL, OpenGL 4.4, DirectX 12
Fanless
16.775 cm 6.88 cm
3-year warranty
Graphics card - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
797 MHz
CUDA Cores
192
Max Resolution
2560 x 1600
3
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA)
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Bandwidth
14.4 GBps
Microsoft Windows Vista / XP / 7 / 8
Required Power Supply
300 W
Software Included
EVGA Precision X, EVGA OC Scanner X
16.775 cm
6.88 cm
Limited warranty - 3 years
