The powerful new GeForce GT 600-series architecture delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that will transform the way you experience all your favorite titles now and in the future.
Key Features
- Microsoft DirectX 11 support: DirectX 11 GPU with Shader Model 5.0 support designed for ultra high performance in the new API's key graphics feature, GPU-accelerated tessellation.
- NVIDIA CUDA technology: CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
- NVIDIA PhysX technology: Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
- NVIDIA PureVideo HD technology: The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
- PCI Express 2.0 support: Designed for the new PCI Express 2.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
- Dual-link HDCP-Capable: Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc format, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays.
- Microsoft Windows 7 Support: Windows 7 is the next generation operating system that will mark a dramatic improvement in the way the OS takes advantage of the graphics processing unit (GPU) to provide a more compelling user experience. By taking advantage of the GPU for both graphics and computing, Windows 7 will not only make today's PCs more visual and more interactive but also ensure that they have the speed and responsiveness customers want. OpenGL 4.0 Support: Ensures top-notch compatibility and performance for OpenGL applications
Performance
- NVIDIA GT 610
- 1536 CUDA Cores
- 810 MHz GPU
- 1024 MB, 64 bit DDR3
- 1000 MHz (effective)
- 8 GB/s Memory Bandwidth
- PCI-E 2.0 16x
- DVI-I, HDMI, VGA
Resolution & Refresh
- 240Hz Max Refresh Rate
- 2048x1536 Max Analog
- 2560x1600 Max Digital
Product Warranty
- This product comes with a 3 year limited warranty. Registration is recommended
Operating System Support
- Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
Requirements
- Minimum of a 300 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 16 Amps.)
The combination of high-definition video decode acceleration and post-processing that delivers stunning picture clarity, smooth video, accurate color, and precise image scaling for movies and video. -
Blu-ray 3D supports
Connect your PC to any 3D enabled TV over HDMI and enjoy a cinematic 3D experience in your home with seamless support for 1080p Blu-ray 3D disc. -
TrueHD and DTS-HD audio bitstreaming
Full supports for TrueHD and DTS-HD advanced lossless multi-channel HD audio code brings the rich sound of the master recording to your living room. -
Microsoft DirectX 11 supports
DirectX 11 GPU with shader model 5.0 supports designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation. -
NVIDIA CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding system tasks - such as photo editing - delivering incredible performance improvements over traditional CPUs. -
Full supports for PhysX technology, enabling a totally class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
NVIDIA adaptive vertical sync
Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. -
HDMI
Supports for HDMI including GPU accelerated Blu-ray 3D supports, x.v. Color, HDMI deep color, and 7.1 digital surround sound. -
Dual-link DVI
Able to drive industries largest and highest resolution flat-panel displays up to 2560 x 1600. -
PCI Express 2.0 supports
Designed for the PCI Express 2.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest supports.
- EVGA GeForce GT 610 - graphics card - GF GT 610 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 610 - up to
- Memory
- 1 GB DDR3
- Core Clock
- 810 MHz
- CUDA Cores
- 48
- Effective Memory Clock
- 1 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- DVI-I (dual link) , HDMI , VGA
- API Supported
- DirectX 11, OpenGL 4.0
- 14.48 cm x 11.15 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- CUDA Cores
- 48
- Max Resolution
- 2560 x 1600
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1 GHz
- Bus Width
- 64-bit
- Bandwidth
- 8 GBps
- OS Required
- Microsoft Windows Vista / XP / 7
- Required Power Supply
- 300 W
- Additional Requirements
- Adjacent PCI slot
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
- 14.48 cm
- 11.15 cm
- 907 g
- Limited warranty - 3 years
