DirectX 11 GPU with Shader support designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation.
CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
Full support for NVIDIA PhysX technology, enabling physical gaming interaction for a more dynamic and realistic experience with GeForce.
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
Designed for the PCI Express bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
Is designed to meet the output protection management (HDCP) and security specifications of the Blu-ray disc format, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays.
NVIDIA GeForce Graphics
Graphics processing has become an essential ingredient to the modern PC. Nowadays, we simply demand more from our PCs. If you want to enhance photos, edit videos, watch movies, play games, or if you simply desire a Premium Windows® 7 Experience, NVIDIA® GeForce® graphics brings impressive graphics processing power to your PC at an incredible value.
Spectacular Video
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them to Facebook up to 50% faster² with the GeForce 210 or GeForce GT520 GPUs. Convert your video and put it on your iPod in minutes instead of hours³ or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-Ray Movies? It doesn’t matter, the GeForce 210 and GT520 can playback any Blu Ray Movie with any modern CPU4.
Gorgeous Graphics
Modern games and 3D applications demand more graphics performance than ever before and Intel integrated graphics simply aren’t good enough. The GeForce 210 delivers over 10x the performance¹ of Intel integrated solutions! If you want to play popular mainstream games like World of Warcraft, Spore or Sims3, the GeForce 210 is an essential addition to your PC. For games that require more performance or DirectX 11 then the GT520 is the ideal graphics processor to get you and your system to the next level.
Premium Windows 7 Experience
Graphics processing units (GPUs) are an essential element of today’s PCs, enabling more visual and more interactive experiences. As a leader in visual computing and the inventor of the GeForce GPU, NVIDIA worked closely with Microsoft on the development of Windows 7 to ensure that its GPUs take full advantage of the great new features and functionality. If you use your PC to enhance photos, watch or edit videos, play games, or if you simply desire a fast and efficient graphical interface, NVIDIA GPUs will surely delight your senses and offer a premium Windows 7 experience.1 Compared to Intel G45. Measured using 3DMark Vantage, Performance Pre-set on a Pentium Dual Core E5200 system with 2GB RAM, Vista SP1.
See NVIDIA GeForce Graphics Cards In Action
2 Compared to E8200 CPU with no GPU. Measured using MotionDSP vReveal on G31 system with 2GB RAM, Vista SP1. 3Comparison made using 30min 720p video clip on a Core2 Duo E8200, G31 system with 2GB RAM, Vista SP1. CPU test run on Apple iTunes. GPU test run on Elemental Technologies Badaboom. 4 Intel Atom CPU or better
Microsoft DirectX 11 support
DirectX 11 GPU with Shader support designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation. -
NVIDIA CUDA technology
CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs. -
Full support for NVIDIA PhysX technology, enabling physical gaming interaction for a more dynamic and realistic experience with GeForce. -
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video. -
PCI Express support
Designed for the PCI Express bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
Dual-link HDCP-capable
Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray disc format, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays.
- EVGA GeForce GT 520 - graphics card - GF GT 520 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 520
- Memory
- 1 GB DDR3
- Core Clock
- 810 MHz
- Effective Memory Clock
- 1 GHz
- Memory Interface
- 64-bit
- DVI-I (dual link) , HDMI , VGA
- API Supported
- DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.1
- 14.5 cm x 11 cm
- 3-year warranty
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 810 MHz
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1 GHz
- Bus Width
- 64-bit
- OS Required
- Microsoft Windows Vista / XP / 7
- Required Power Supply
- 300 W
- Software Included
- Drivers & Utilities, EVGA Precision, EVGA OC Scanner
- 14.5 cm
- 11 cm
- 0.9 kg
- Limited warranty - 3 years
