EVGA SuperNOVA power supplies are well-known for their extreme efficiency, performance and reliability. The SuperNOVA G3's smaller size, improved performance and a hydraulic dynamic bearing fan give you ultra-quiet performance with an increased lifespan.
Small size, big performance
A reduced size does not mean reduced performance with the EVGA SuperNOVA G3 power supplies. The small power supplies offer improved performance and features. -
Hydraulic dynamic bearing fan
Better performance, quieter operation and a longer lifespan. -
Amazing performance
Advanced systems deserve improved performance. The EVGA SuperNOVA G3 makes it even better with improved efficiency and lower ripple. These power supplies are extremely efficient! -
Whisper-quiet
EVGA ECO mode means, the power supply is completely silent during low to medium loads. This is one quiet power supply!
- EVGA SuperNOVA 850 G3 - power supply - 850 watt
- Power supply - internal
- Specification Compliance
- ATX12V / EPS12V
- 80 PLUS Certification
- 80 PLUS Gold
- 3.63 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 watt
- Output Current
- +3.3V - 24 A , +5V - 24 A , +12V - 70.8 A , +5VSB - 3 A , -12V - 0.5 A
- Output connectors
- 1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 130 mm fan
- 15 cm x 15 cm x 8.5 cm
- 10 years warranty
- ATX12V / EPS12V
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 watt
- Output Current
- Efficiency
- 90% (115VAC) / 92% (220-240VAC)
- 80 PLUS Gold
- MTBF
- 100,000 hour(s)
- Cooling System
- 130 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, ECO Intelligent Thermal Control System, fluid dynamic bearing cooling fan, fully modular
- TUV, CB, FCC, RoHS, WEEE, cTUVus, Energy-Related Products (ErP) Lot 6, RCM
- Limited warranty - parts and labour - 10 years
- 0 °C
- 50 °C
- 15 cm
- 15 cm
- 8.5 cm
- 3.63 kg
