The EVGA 700B Power Supply is the best value for your next build. With 80 Plus Bronze standard, over 85% efficiency under typical loads, the EVGA 700B is a great choice. Combining 700W of continuous power make and a single + 12V supporting 56A, make this the perfect power supply for a high performance SLI system. Stay protected with a series of multiple safety protections all bundled into one!
- EVGA 700B Bronze - power supply - 700 Watt
- Power supply - internal
- Specification Compliance
- ATX12V / EPS12V
- 80 PLUS Certification
- 80 PLUS Bronze
- 2.3 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- +5V - 20 A , +3.3V - 24 A , +12V - 56 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.5 cm
- 3-year warranty
- ATX12V / EPS12V
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- Efficiency
- 85%
- 80 PLUS Bronze
- Cables Included
- Power cable - external - 1.2 m
- MTBF
- 100,000 hour(s)
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
- UL, TUV, cUL, CB, FCC, RoHS, WEEE, ErP 2013
- Limited warranty - parts and labour - 3 years
- 0 °C
- 50 °C
- 15 cm
- 14 cm
- 8.5 cm
- 2.3 kg
