Euroscreen Manual Pull Down 210cm x 158cm Viewing Area 103" Diagon
Quicklinx: BYK1WS00 Mfr#: DD2217-V
Diplomat is a high quality screen which, thanks to the robust construction and flexible installation, is the preferred screen among the professional buyers. The installation is very flexible with mounting brackets that can be adjusted sideways to preferred positions. The screen can be mounted on the wall as well as in the ceiling.
Euroscreen Diplomat Video Format - projection screen - 104" (263 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
White
Projection Screen Image Diagonal Size
104" (263 cm)
Projection Image Size
210 cm x 158 cm
Aspect Ratio
4:3
Screen Surface
Matte White
229 cm
11.8 kg
Projection screen
Placing / Mounting
Image Diagonal Size
104" (263 cm)
Image Width
210 cm
Image Height
158 cm
Screen Surface
Matte White
Aspect Ratio
4:3
Border Size
5 cm
Black borders, pull down
229 cm
11.8 kg
White
Mounting Kit
Included
