Connect is a basic compact screen which is very easy to install. The case is made of steel. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case.
- Euroscreen Connect Wide Format - projection screen
- Product Type
- Projection screen
- Placing / Mounting
- Ceiling mountable, wall mountable
- Projection Image Size
- 170 cm x 95 cm
- Aspect Ratio
- 16:9
- Screen Surface
- Matte White
- 189 cm 165 cm
- 7.3 kg
- Product Type
- Projection screen
- Image Width
- 170 cm
- Image Height
- 95 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:9
- Viewing Angle
- 180°
- 189 cm 165 cm
- 7.3 kg
