Euroscreen 150x150cm Connect Electric
Quicklinx: 64TMWS00 Mfr#: CEL150-UK
Connect Electric is a basic compact screen which is very easy to install. The case is made of steel and painted white. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case. The screen can be operated by an in-line switch, an IR remote control or automatically by an AutoLink connected to the projector. All control options are easily connected to the screen via the universal connector on the screens left side.
The screen is operated by a 3-positions in-line switch.
Euroscreen Connect Electric Square Format - projection screen
Projection screen - motorised - 220 V
Placing / Mounting
Ceiling mountable, wall mountable
Projection Image Size
150 cm x 150 cm
Aspect Ratio
1:1
Screen Surface
Matte White
159 cm 150 cm
Placing / Mounting
Image Width
150 cm
Image Height
150 cm
Screen Surface
Matte White
Aspect Ratio
1:1
Viewing Angle
180°
159 cm 150 cm
