Connect is a basic compact screen which is very easy to install. The case is made of steel and painted white. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case. The screen is operated manually.
- Draper Connect Video Format - projection screen - 113" (288 cm)
- Product Type
- Projection screen
- Placing / Mounting
- Ceiling mountable, wall mountable
- White
- Projection Screen Image Diagonal Size
- 113" (288 cm)
- Projection Image Size
- 230 cm x 173 cm
- Aspect Ratio
- 4:3
- Screen Surface
- Arctiq
- 249 cm
- 10.3 kg
- Product Type
- Projection screen
- Image Diagonal Size
- 113" (288 cm)
- Image Width
- 230 cm
- Image Height
- 173 cm
- Screen Surface
- Arctiq
- Aspect Ratio
- 4:3
- Gain
- 1.0x
- Viewing Angle
- 180°
- Screen Thickness
- 0.37 mm
- Border Size
- 5 cm
- Mildew-resistant, washable, black backing, black borders, flame retardant
- 249 cm
- 10.3 kg
- White
- Dust-resistant
