Ergotron Zip40 Charging Cart
Quicklinx: C6HXWS00 Mfr#: DM40-1009-3
The one cart that gets it all done! The Zip40 is a truly universal cart for transporting, securing, protecting and charging all your mobile computing devices: Use it with tablets, Chromebook, Ultrabook, MacBook and laptops - almost any device with a display size up to 15.6". Integrated PowerShuttle Technology optimizes total charge time while safely preventing electrical circuit overload.
Ergotron Zip40 Charging Cart cart - for 40 tablets / notebooks - black, silver
Cart
77 cm x 66 cm x 115 cm
79 kg
United Kingdom, Ireland
Recommended Use
Recommended Display Size
Up to 15.6"
Outlets Qty
40
Max Load Weight
116 kg
Material
Steel
Black, silver
Wheels Qty
4
10 years warranty
77 cm
66 cm
115 cm
79 kg
Material
Steel
Black, silver
AV Furniture
Cart
Recommended Use
Shelf Qty
3
Cable Management
Integrated cable management
Up to 15.6"
Max Load Weight
116 kg
Wheels Qty
4
Brakes Qty
4
Lockable, PowerShuttle, on/off power switch, dividers, UL 60950 certified, three-point locking mechanisms
Outlets Qty
40
Limited warranty - parts and labour - mechanical components - 10 years , Limited warranty - cables - 1 year , Limited warranty - electrical components - 2 years
