Ideal for corner workstations, the WorkFit-A clamps to the rear or side of most surfaces and enables an effortless sit-and-stand work style. Fold the keyboard up and swing the arm out of the way when you need your desk surface.
Change from a sitting to a standing position whenever you want. This height-adjustable desk workstation moves your keyboard and display in one simple motion, making computing comfortable for prolonged periods.
- Ergotron WorkFit-A LCD HD with Worksurface+ Standing Desk mounting kit - for LCD display / keyboard / mouse - polished aluminium
- Product Type
- Mounting kit - desktop
- Mounting Components
- Desk clamp mount, pivot, flexible arm, keyboard tray, work surface
- Tilt
- 30°
- Pan
- 180°
- Lift
- 50.8 cm
- Rotation
- 360°
- Recommended Use
- LCD display / keyboard / mouse
- Recommended Display Size
- Up to 30"
- Max Load Weight
- 11.3 kg
- Polished aluminium
- 5-year warranty
AV Furniture
- Mounting kit
- Recommended Use
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- Up to 30"
- Tilt
- 30°
- Pan
- 180°
- Lift
- 50.8 cm
- Rotation
- 360°
- Max Load Weight
- 11.3 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 94 cm x 53.3 cm x 29.2 cm / 22 kg
- Limited warranty - 5 years
