Ergotron StyleView Sit-Stand Combo Arm Mounting Kit
Quicklinx: BPN3WS00 Mfr#: 45-266-216
More than 50 In Stock
£540.14 ex VAT
£648.16 inc VAT
Durable aluminum construction! It holds a monitor, bar-code scanner, keyboard, wrist rest and mouse on the same arm, providing easy, single-motion height adjustment. Work sitting or standing with the arm's ergonomic 25" LCD height adjustment range. A unique cable management system conceals and organizes cords, making cleaning easy.
  • Versatile adjustments
    With height, pan, rotation, and tilt adjustments, the Ergotron StyleView Sit-Stand Combo offers flexibility. This allows users to customize their viewing angle, height, and position for an optimal ergonomic setup, enhancing comfort during long hours of use.
  • Seamless cable management
    The integrated cable management system ensures that cables are neatly organized and hidden away. This feature not only keeps the workspace tidy but also reduces the risk of accidents, making it safer and more professional.
  • Durable construction
    Constructed from aluminum and high-grade plastic, the Ergotron StyleView Sit-Stand Combo is designed for durability and long-term use. This robust construction supports up to 13.2 kg, accommodating a wide range of LCD displays and devices.
  • Comprehensive mounting solution
    Featuring an articulating arm and a keyboard tray, this mounting kit is a comprehensive solution for setting up an LCD display alongside a keyboard, mouse, and barcode scanner. Its wall-mountable design saves valuable desk space and promotes a clutter-free environment.
Ergotron StyleView Sit-Stand Combo mounting kit - for LCD display / keyboard / mouse / barcode scanner - white
Mounting kit - wall-mountable
Mounting Components
Articulating arm, keyboard tray
Tilt
+25° to -5°
Pan
360°
Lift
63 cm
Rotation
360°
Adjustments
Height, tilt, rotation, pan
11.2 kg
Recommended Use
Recommended Display Size
Up to 24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
13.2 kg
Material
Aluminium, high-grade plastic
White
5-year warranty
11.2 kg
Material
White
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
Up to 24"
Tilt
+25° to -5°
Pan
360°
Lift
63 cm
Rotation
360°
Adjustments
Max Load Weight
13.2 kg
Dimensions & Weight Details
Dimensions
Keyboard tray - width: 47.2 cm, depth: 22.8 cm
64.8 cm x 56.1 cm x 28.2 cm / 14.1 kg
Limited warranty - 5 years
Brand: Ergotron
Price Range Ex VAT: £500 - £750
