Ergotron Side by Side Mount
Quicklinx: 6MDLWS00 Mfr#: 45-245-026
Accessory Type: Mount
More than 50 In Stock
£243.25 ex VAT
£291.90 inc VAT
Durable polished aluminum construction! Create a fully adjustable side-by-side configuration that lifts both LCD screens up to where they're easier to see while reclaiming valuable worksurface.
Reposition your LCDs with just a touch. Up. Down. Forward. Back. The LX provides unparalleled range of motion. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs.
  • Effortless adjustability
    Experience the freedom to adjust your dual displays effortlessly with height, lift, pan, rotation, and tilt capabilities, all thanks to the Constant Force Technology. This innovative design ensures your screens are always in the optimal position for comfort and productivity.
  • Seamless cable management
    Keep your workspace tidy and organized with integrated cable management. This feature allows you to route your cables neatly, reducing clutter and maintaining a clean, professional look on your desk.
  • Robust and versatile design
    Constructed from high-quality aluminum and steel, the Ergotron LX Dual Side-by-Side Arm is built to last. It supports two LCD displays up to 27 inches and 18.1 kg in total, offering a range of mounting components for a customized setup.
  • Full motion articulation
    Enjoy the flexibility to move your displays from portrait to landscape orientation effortlessly and rotate them 360° for the best viewing angles. A tilt range of 75° further enhances your viewing comfort, making it easier to share your screen and reduce glare.
Ergotron LX Dual Side-by-Side Arm mounting kit - Constant Force Technology - for 2 LCD displays - polished aluminium
Mounting kit (Constant Force Technology)
Mounting Components
Desk clamp mount, grommet mount, pole, 2 articulating arms, 2 extension brackets, t-bracket, base
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Height, pan, tilt, rotation, lift
6.3 kg
Recommended Use
2 LCD displays
Recommended Display Size
Up to 27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
18.1 kg
Material
Aluminium, steel
Polished aluminium
10 years warranty
6.3 kg
Material
Aluminium, steel
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Design
Recommended Use
2 LCD displays
Cable Management
Integrated cable management
Up to 27"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Max Load Weight
18.1 kg
Min Load Weight
6.4 kg
Rotating, portrait to landscape movement
Dimensions & Weight Details
49 cm x 45 cm x 16 cm / 7.9 kg
Limited warranty - 10 years
6MDL ErgoMounts 50-193-200 Notebook Tray In Stock £39.07
6MDL Ergotron Thin Client Mounting Kit In Stock £36.04
Brand: Ergotron
