Durable polished aluminum construction! Create a fully adjustable side-by-side configuration that lifts both LCD screens up to where they're easier to see while reclaiming valuable worksurface.
Reposition your LCDs with just a touch. Up. Down. Forward. Back. The LX provides unparalleled range of motion. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs.
Effortless adjustability
Experience the freedom to adjust your dual displays effortlessly with height, lift, pan, rotation, and tilt capabilities, all thanks to the Constant Force Technology. This innovative design ensures your screens are always in the optimal position for comfort and productivity. -
Seamless cable management
Keep your workspace tidy and organized with integrated cable management. This feature allows you to route your cables neatly, reducing clutter and maintaining a clean, professional look on your desk. -
Robust and versatile design
Constructed from high-quality aluminum and steel, the Ergotron LX Dual Side-by-Side Arm is built to last. It supports two LCD displays up to 27 inches and 18.1 kg in total, offering a range of mounting components for a customized setup. -
Full motion articulation
Enjoy the flexibility to move your displays from portrait to landscape orientation effortlessly and rotate them 360° for the best viewing angles. A tilt range of 75° further enhances your viewing comfort, making it easier to share your screen and reduce glare.
- Ergotron LX Dual Side-by-Side Arm mounting kit - Constant Force Technology - for 2 LCD displays - polished aluminium
- Product Type
- Mounting kit (Constant Force Technology)
- Mounting Components
- Desk clamp mount, grommet mount, pole, 2 articulating arms, 2 extension brackets, t-bracket, base
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, rotation, lift
- 6.3 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- Up to 27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 18.1 kg
- Material
- Aluminium, steel
- Polished aluminium
- 10 years warranty
- 6.3 kg
- Material
- Aluminium, steel
AV Furniture
- Mounting kit
- Design
- Recommended Use
- 2 LCD displays
- Cable Management
- Integrated cable management
- Up to 27"
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 18.1 kg
- Min Load Weight
- 6.4 kg
- Rotating, portrait to landscape movement
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 49 cm x 45 cm x 16 cm / 7.9 kg
- Limited warranty - 10 years
ErgoMounts 50-193-200 Notebook Tray | In Stock | £39.11 |
Ergotron Thin Client Mounting Kit | In Stock | £24.22 |
