Ergotron Neo-Flex Laptop Cart
Quicklinx: BXRWWS00 Mfr#: 24-205-214
£623.36 ex VAT
£748.03 inc VAT
Designed for manufacturing floors, clinical documentation, labs, distribution centers, and high activity areas, the lightweight streamlined Neo-Flex cart transforms any space into a productive sit-stand computing environment. Creating an optimal platform for point-of-need data input, the Neo-Flex cart helps improve viewing comfort, increase user accuracy and productivity while supporting wireless initiatives.
The Laptop Cart features Ergotron's constant force patented lift technology, 20-inch (51cm) effortless lift range, and an integrated laptop security system for theft deterrence and stability. Complete with a flexible open architecture design, this secure, low-cost solution supports mobile computing needs today and tomorrow.
  • Effortless mobility
    Equipped with four high-quality wheels, this cart allows for smooth movement across various surfaces, ensuring your essential devices are always within reach.
  • Versatile adjustments
    Featuring Constant Force Technology, the Ergotron Neo-Flex cart offers adjustable height options, making it easy to find the perfect viewing angle for comfort and productivity.
  • Durable construction
    Constructed from a combination of aluminum, high-grade plastic, and steel, and finished with zinc-plated powder coating, this cart is designed for longevity and resilience in any environment.
Ergotron Neo-Flex cart - for notebook / mouse / barcode scanner - two-tone grey
Cart
Adjustable Height
68-118 cm
Adjustments
15.4 kg
Recommended Use
Notebook / mouse / barcode scanner
Recommended Display Size
12"-17.3"
Max Load Weight
6.8 kg
Material
High-grade plastic, aluminium, steel
Two-tone grey
Wheels Qty
4
3-year warranty
Adjustable Height
68-118 cm
15.4 kg
Material
Two-tone grey
AV Furniture
Cart
Recommended Use
12"-17.3"
Adjustments
Max Load Weight
6.8 kg
Wheels Qty
4
Brakes Qty
2
Finish
Zinc plated powder coated
Adjustable height, wheels, Constant Force Technology
Dimensions & Weight Details
Dimensions
Worksurface - width: 42 cm, depth: 44 cm , Base - width: 45 cm, depth: 58 cm
55 cm x 38 cm x 115 cm / 23.6 kg
Limited warranty - 3 years
Brand: Ergotron
Price Range Ex VAT: £500 - £750
