Affordable, height-adjustable dual-monitor stand for maximum productivity and comfort. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs. Simultaneously lift LCD screens to proper height for unsurpassed ergonomic comfort.
Flexible positioning
With adjustments for lift, pan, and rotation, the Ergotron Neo-Flex stand offers flexibility. Users can easily adjust the height, pan 360°, and rotate their displays full circle, ensuring the ideal viewing angle for every task. -
Dual display capability
Designed to support two LCD displays up to 24 inches or 61 cm, this stand maximizes workspace efficiency. The ability to use dual screens simultaneously enhances productivity and provides a seamless multitasking experience. -
Easy installation
The stand comes equipped with a VESA adapter kit, sliding brackets, and cable ties, facilitating a straightforward setup process. Its compatibility with 100 x 100 mm and 75 x 75 mm flat panel mount interfaces ensures it fits a wide range of display models. -
Robust design
Capable of supporting a minimum load weight of 6.4 kg and a maximum of 15.4 kg, the Ergotron Neo-Flex stand is built for durability and reliability. Its sturdy construction ensures stability for your displays, providing peace of mind during use.
 - Ergotron Neo-Flex stand - for 2 LCD displays - black
- Product Type
 - Stand - desktop
- Pan
 - 360°
- Lift
 - 12.7cm
- Rotation
 - 360°
- Adjustments
 - Rotation, lift, pan
 - 7.2 kg
- Recommended Use
 - 2 LCD displays
- Recommended Display Size
 - Up to 24"
- VESA Mounting Interface
 - 100 x 100 mm, 75 x 75 mm
- Max Load Weight
 - 15.4 kg
 - Black
- Package Content
 - Crossbar, cable ties, VESA adapter kit, 2 x sliding brackets
 - 3-year warranty
 - 7.2 kg
 - Black
- Package Content
AV Furniture
 - Stand
- Recommended Use
 - 2 LCD displays
- Placing / Mounting
 - Desktop
 - Up to 24"
- Pan
 - 360°
- Lift
 - 12.7cm
- Rotation
 - 360°
- Adjustments
- Max Load Weight
 - 15.4 kg
- Min Load Weight
 - 6.4 kg
 - Adjustable height, rotating
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
 - 98 cm x 41 cm x 17 cm / 9.5 kg
 - Limited warranty - 3 years
