Ergotron LX Sit-Stand Wall Mount LCD Arm
Quicklinx: 9LH5WS00 Mfr#: 45-353-026
£199.94 ex VAT
£239.92 inc VAT
This versatile arm can be used in a variety of applications: attach a smaller monitor for use within a sit-stand workstation or add a large display up to 11.3 kg to position digital signage.
The LX provides unparalleled range of motion, being able to accommodate a user's sitting or standing posture - features 20 inches of vertical adjustment and 62 inches of side-to-side adjustment.
Ergotron LX mounting kit - for LCD display - capacity 3.2-11.3 kg - polished aluminium
Mounting kit - wall-mountable
Mounting Components
Sit-stand arm, extension, base, VESA adapter
Adjustable Depth
Up to 83.2 cm
Tilt
-5° to 70°
Pan
180°
Rotation
360°
Adjustments
Pan, tilt, height, rotation, swivel, depth
5 kg
Recommended Use
LCD display
Recommended Display Size
Up to 42"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
11.3 kg
Polished aluminium
10 years warranty
Adjustable Depth
Up to 83.2 cm
5 kg
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
Up to 42"
Tilt
-5° to 70°
Pan
180°
Rotation
360°
Adjustments
Max Load Weight
11.3 kg
Min Load Weight
3.2 kg
Horizontal or vertical screen orientation, rotating
Dimensions & Weight Details
Dimensions
Base - width: 8 cm, depth: 7.8 cm, height: 21.3 cm
56 cm x 28 cm x 19 cm / 5.7 kg
Limited warranty - 10 years
9LH5 ErgoMounts 50-193-200 Notebook Tray In Stock £38.88
9LH5 Ergotron Thin Client Mounting Kit In Stock £37.62
9LH5 Ergotron Wall Mount Barcode Scanner Holder In Stock £19.64
Brand: Ergotron
