This versatile arm can be used in a variety of applications: attach a smaller monitor for use within a sit-stand workstation or add a large display up to 11.3 kg to position digital signage.
The LX provides unparalleled range of motion, being able to accommodate a user's sitting or standing posture - features 20 inches of vertical adjustment and 62 inches of side-to-side adjustment.
- Ergotron LX mounting kit - for LCD display - capacity 3.2-11.3 kg - polished aluminium
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Sit-stand arm, extension, base, VESA adapter
- Adjustable Depth
- Up to 83.2 cm
- Tilt
- -5° to 70°
- Pan
- 180°
- Rotation
- 360°
- Adjustments
- Pan, tilt, height, rotation, swivel, depth
- 5 kg
- Recommended Use
- LCD display
- Recommended Display Size
- Up to 42"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 11.3 kg
- Polished aluminium
- 10 years warranty
- Adjustable Depth
- Up to 83.2 cm
- 5 kg
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- Up to 42"
- Tilt
- -5° to 70°
- Pan
- 180°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 11.3 kg
- Min Load Weight
- 3.2 kg
- Horizontal or vertical screen orientation, rotating
Dimensions & Weight Details
- Dimensions
- Base - width: 8 cm, depth: 7.8 cm, height: 21.3 cm
- Shipping Dimensions (WxDxH) / Weight
- 56 cm x 28 cm x 19 cm / 5.7 kg
- Limited warranty - 10 years
ErgoMounts 50-193-200 Notebook Tray | In Stock | £38.49 |
Ergotron Thin Client Mounting Kit | In Stock | £24.22 |
