Product
Ergotron LX Dual Stacking Arm - mounting kit
Quicklinx: 7Z7PWS00 Mfr#: 45-248-026
Accessory Type: Mount
40 in stock
£193.66 ex VAT
£232.39 inc VAT
Durable polished aluminum construction! Use this ingenious tool with your notebook and an external LCD or with two LCDs. Create a productive multi-display configuration that lifts screens up to where they're easier to see while reclaiming valuable worksurface.
  • Versatile
    Use with a notebook and LCD or with two LCDs.
  • Easy to use
    Simple installation and effortless operation.
Mounting kit - desktop
Mounting Components
Desk clamp mount, grommet mount, pole, 2 articulating arms, 2 extension brackets, notebook tray
Integrated Devices
Flat panel lift
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Height, pan, tilt, rotation
Recommended Use
2 LCD displays or LCD display and notebook
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
18.1 kg
Material
Polished aluminium
5 years warranty
Material
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Desktop
Integrated Devices
Flat panel lift
Cable Management
Integrated cable management
Up to 24"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Max Load Weight
18.1 kg
Adjustable height, rotating
Dimensions & Weight Details
48.7 cm x 38.7 cm x 22.9 cm / 7.18 kg
Limited warranty - 5 years
Ergotron LX Dual Stacking Arm - mounting kit Bundle deal on Ergotron LX Dual Stacking Arm - mounting kit
£293.42
Brand: Ergotron
Price Range Ex VAT: 150 - 300
