Ergotron LX Desk Mount LCD Arm Tall Pole
Quicklinx: BQ39WS00 Mfr#: 45-295-026
Accessory Type: Mount
Hurry, only 1 left in stock!
£158.28 ex VAT
£189.93 inc VAT
Durable polished aluminum construction! Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. Up. Down. Forward. Back. The LX provides unparalleled range of motion.
Ergotron LX mounting kit - for LCD display - polished aluminium
Mounting kit
Mounting Components
Desk clamp mount, extender arm, grommet-mount base, monitor arm, tall pole
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Tilt, pan, lift, rotation
Recommended Use
LCD display
Recommended Display Size
Up to 34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Polished aluminium
10 years warranty
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Cable Management
Integrated cable management
Up to 34"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Max Load Weight
11.3 kg
Min Load Weight
3.2 kg
Adjustable height, rotating
Dimensions & Weight Details
Dimensions
Pole - height: 34 cm
29 cm x 18 cm x 59 cm / 5 kg
Limited warranty - 10 years
Brand: Ergotron
