Ergotron DeskStand DS100 Stand
Quicklinx: 73VFWS00 Mfr#: 33-091-200
Accessory Type: Stand
£279.49 ex VAT
£335.38 inc VAT
The DS100 Series is a line of products within Ergotron's flat panel monitor Adjustable Rotating Mounting Solutions (ARMS). Conserve desk space by suspending flat panel monitors on a single base. Choose between multiple configurations and adjustment ranges. Easily adjust the height and position of all monitors to a comfortable, ergonomically appropriate position. Patented pivot mechanisms allow you to tilt, pivot and turn your flat panel monitors for maximum efficiency and ergonomic comfort. Free Standing, Desk Clamp, and Grommet Mount Bases are available for all configurations. This Free Standing Base Vertical Double Monitor configuration manages from 15" to 20" flat panel monitors and up to 23 lbs.
  • Versatile adjustments
    Offering pan, rotation, and tilt adjustments, the DS100 mounting kit provides the flexibility to position two LCD displays exactly as needed for optimal viewing. This adaptability ensures a comfortable and productive workspace.
  • Robust build quality
    Constructed from high-grade aluminum and steel, the DS100 is designed for durability and stability. Its low-profile design and cable management system enhance the aesthetic of any desktop setup while ensuring a clutter-free environment.
  • Easy installation
    With included VESA adapters, pivots, a 28" pole, and base, the DS100 mounting kit supports easy setup for two LCD displays up to 27". The comprehensive package content, including mounting hardware, facilitates a hassle-free installation process.
Ergotron DS100 mounting kit - low profile - for 2 LCD displays - black
Mounting kit (low profile) - desktop
Mounting Components
28" pole, base, 2 pivots, 2 VESA adapters
Tilt
180°
Pan
180°
Rotation
360°
Adjustments
Tilt, pan, rotation
Recommended Use
2 LCD displays
Recommended Display Size
Up to 27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
20.9 kg
Material
Steel, aluminium
Package Content
Mounting hardware
5-year warranty
Material
Steel, aluminium
Package Content
Mounting hardware
AV Furniture
Mounting kit
Mounting Components
Design
Low profile
Recommended Use
2 LCD displays
Placing / Mounting
Desktop
Cable Management
Cable Management System (CMS)
Up to 27"
Tilt
180°
Pan
180°
Rotation
360°
Adjustments
Tilt, pan, rotation
Max Load Weight
20.9 kg
Rotating
Details
Portrait orientation
Dimensions & Weight Details
Dimensions
Pole - height: 71.1 cm
71.1 cm x 40.6 cm x 19.1 cm / 7.3 kg
Limited warranty - 5 years
Brand: Ergotron
