Ergotron AIO Stand
Ergotron AIO Stand
Quicklinx: BS1JWS00 Mfr#: 33-387-085
Hurry, only 1 left in stock!
£92.36 ex VAT
£110.83 inc VAT
A robust hinge mechanism provides an incredible 115 degrees of tilt adjustment while simultaneously controlling monitor height. This flexibility allows the screen to be moved parallel with the desktop - perfect for touchscreen applications.
This stand's strength and heavy-duty design also make it well suited for use with all-in-one PCs and hefty displays.
Ergotron Neo-Flex Touchscreen Stand stand - for touch screen - black
Stand - desktop
32.5 cm x 27.7 cm x 29.8 cm
Tilt
115°
Pan
360°
Lift
16.5 cm
Adjustments
Pan, tilt, lift
Recommended Use
Touch screen
Recommended Display Size
Up to 27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10.8 kg
Package Content
Adjustment tool, hinged arm, hinged pivot, base
3-year warranty
32.5 cm
27.7 cm
29.8 cm
Package Content
AV Furniture
Stand
Recommended Use
Touch screen
Placing / Mounting
Desktop
Cable Management
Integrated cable management
Up to 27"
Tilt
115°
Pan
360°
Lift
16.5 cm
Adjustments
Pan, tilt, lift
Max Load Weight
10.8 kg
Min Load Weight
6.4 kg
Adjustable height
Details
Portrait orientation, landscape orientation
Dimensions & Weight Details
40.6 cm x 34.3 cm x 23 cm / 4.5 kg
Limited warranty - 3 years
Brand: Ergotron
