Ergotron 45-266-026 StyleView Sit-Stand Combo Arm
Quicklinx: B5Z6WS00 Mfr#: 45-266-026
Hurry, only 2 left in stock!
£572.32 ex VAT
£686.78 inc VAT
Durable polished aluminum construction! Holds a monitor, bar-code scanner, keyboard, wrist rest and mouse on the same arm, providing easy, single-motion height adjustment. Work sitting or standing with the arm's ergonomic 25" (64 cm) LCD height adjustment range. A unique cable management system conceals and organizes cords, making cleaning easy.
Ergotron StyleView mounting kit - for LCD display / keyboard / mouse / barcode scanner - polished aluminium
Mounting kit
Mounting Components
Wrist rest, track mount bracket kit, height adjust bracket, keyboard tray with left/right mouse tray, barcode scanner and mouse holder, combo arm
Tilt
30°
Pan
360°
Lift
63.5 cm
Rotation
360°
Adjustments
Lift, tilt, pan, rotation
11.2 kg
Recommended Use
Recommended Display Size
Up to 24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
13.2 kg
Polished aluminium
Package Content
Handle, cable ties, wall plate, VESA adapter kit
5-year warranty
11.2 kg
Polished aluminium
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Up to 24"
Tilt
30°
Pan
360°
Lift
63.5 cm
Rotation
360°
Adjustments
Max Load Weight
13.2 kg
Adjustable height, portrait to landscape movement
Dimensions & Weight Details
64.8 cm x 56.1 cm x 28.2 cm / 14.1 kg
Limited warranty - 5 years
Brand: Ergotron
Price Range Ex VAT: £500 - £750
