Ergotron 45-234-200 200 Series Wall Mount Arm
Quicklinx: B8YBWS00 Mfr#: 45-234-200
£187.81 ex VAT
£225.37 inc VAT
Extend or retract, swing, tilt or turn your flat panel monitor for maximum efficiency and ergonomic comfort. The 200 series' slim profile saves space, yet moves your screen to where you need it most.
Ergotron 200 Series mounting kit - for Monitor - black
Mounting kit - wall-mountable
Mounting Components
Wall arm
Tilt
180°
Pan
360°
Rotation
90°
Adjustments
Tilt, pan, rotation
Recommended Use
Monitor
Recommended Display Size
Up to 32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Steel
5-year warranty
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Wall arm
Recommended Use
Monitor
Placing / Mounting
Wall-mountable
Up to 32"
Tilt
180°
Pan
360°
Rotation
90°
Adjustments
Tilt, pan, rotation
Max Load Weight
11.3 kg
Rotating, portrait to landscape movement
Dimensions & Weight Details
14 cm x 40.6 cm x 41.9 cm / 3.9 kg
Limited warranty - 5 years
Brand: Ergotron
