ErgoMounts Neo-Flex LCD Stand Stan
Quicklinx: 6N48WS00 Mfr#: 33-310-060
Type: Stand
More than 50 In Stock
£47.65 ex VAT
£57.18 inc VAT
Instantly set the height of your LCD for a more comfortable computing experience. With fingertip effort, raise or lower your LCD 5" (130 mm), pan left/right, tilt forward/back, and rotate your screen for portrait/landscape viewing.
Upgrade monitors or TVs with improved ergonomic adjustability. Patented CF lift-and-pivot motion technology provides premium adjustment. Neo-Flex is the only weight-adjustable desk stand LCD accessory on the market. Easily position your LCD for maximum comfort and productivity. 5" vertical adjustment enhances ergonomics for multiple users. Sleek, durable, easy-to-clean plastic exterior.
  • Flexible stand
    Positions monitor up and down for your ideal height.
  • Easy adjustment
    Offers 5" (13 cm) of height adjustment.
  • Medium size
    Supports a screen up to 24" and up to 16 lbs. (7.3 kg).
  • Unique design
    Only weight-adjustable desk stand available.
  • Personalized views
    Pan, tilt or rotate your screen as you work.
Ergotron Neo-Flex stand - for Monitor - black, silver
Stand - desktop
47 cm x 23 cm x 16 cm
Tilt
30°
Pan
270°
Rotation
360°
Adjustments
Tilt, pan, rotation
2.7 kg
Recommended Use
Monitor
Recommended Display Size
Up to 27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
7.3 kg
Black, silver
3-year warranty
47 cm
23 cm
16 cm
2.7 kg
Black, silver
AV Furniture
Stand
Recommended Use
Monitor
Placing / Mounting
Desktop
Up to 27"
Tilt
30°
Pan
270°
Rotation
360°
Adjustments
Tilt, pan, rotation
Max Load Weight
7.3 kg
Min Load Weight
2.7 kg
Adjustable height, rotating
Limited warranty - 3 years
Type: Stand
Brand: ErgoMounts
