Durable polished aluminum construction! Tested to perform 10 times the expected life-cycle of other competitive brands at roughly half the price. Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
- Ergotron LX mounting kit - for LCD display - polished aluminium
- Product Type
- Mounting kit
- Mounting Components
- Wall mount, monitor arm
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Tilt, pan, lift, rotation
- 2.5 kg
- Recommended Use
- LCD display
- Recommended Display Size
- Up to 34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 11.3 kg
- Material
- Aluminium
- Polished aluminium
- 10 years warranty
- 2.5 kg
- Material
- Aluminium
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Up to 34"
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 11.3 kg
- Min Load Weight
- 3.2 kg
- Horizontal or vertical screen orientation, adjustable height, rotating
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 44.5 cm x 19.7 cm x 16.8 cm / 2.8 kg
- Limited warranty - 10 years
Ergotron Thin Client Mounting Kit | In Stock | £24.22 |
