Durable polished aluminum construction! Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
Comfortable fit
Offers ergonomic monitor positioning using patented Constant Force Technology. -
More motion
Luxury arm easily adjusts monitors up to 34" in size. -
Saves space
Places screen in the best view to tackle each to-do. -
Sleek build
Streamlined look enhances your work area. -
Easy storage
Folds to fit under storage shelves or cabinets. -
Quality design
Built for years of use by passing a 10,000-cycle motion test.
- Ergotron LX mounting kit - for LCD display - polished aluminium
- Product Type
- Mounting kit
- Mounting Components
- Articulating arm, desk clamp mount, extension adapter, grommet-mount base, 7" post
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Tilt, pan, lift, rotation
- 3.6 kg
- Recommended Use
- LCD display
- Recommended Display Size
- Up to 34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 11.3 kg
- Polished aluminium
- 10 years warranty
- 3.6 kg
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- Up to 34"
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 11.3 kg
- Min Load Weight
- 3.2 kg
- Horizontal or vertical screen orientation, adjustable height, rotating
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 45 cm x 27 cm x 17 cm / 4.4 kg
- Limited warranty - 10 years
ErgoMounts 50-193-200 Notebook Tray | In Stock | £38.88 |
Ergotron Thin Client Mounting Kit | In Stock | £37.62 |
