ErgoMounts Ergotron WM mounting kit - low profile - for flat panel - silver
Quicklinx: 7FDLWS00 Mfr#: 60-604-003
Type: Mounting kit
Hurry, only 3 left in stock!
£94.43 ex VAT
£113.31 inc VAT
The WM's wall-hugging design hangs your large flat panel display just over an inch from the wall for an extremely slim profile. Yet this TV wall mount costs about half that of competing models. Engineered to install in three easy steps, the WM is sturdy and stable.
  • Protect your investment
    Integrated security fasteners hold display in place and deter others from removing your display
  • Premium construction
    It is composed of extruded aluminum and steel.
Mounting kit (low profile)
Mounting Components
Wall plate, 2 brackets
70.4 cm x 3.2 cm x 48.3 cm
Recommended Use
Flat panel
Recommended Display Size
32"-120"
VESA Mounting Interface
From 100 x 100 mm, up to 600 x 450 mm
Max Load Weight
79.4 kg
Mounting Stud Centers
16"
Material
Extruded aluminium, steel
Silver
Package Content
Fasteners
5-year warranty
70.4 cm
3.2 cm
48.3 cm
Material
Silver
Package Content
Fasteners
AV Furniture
Mounting kit
Mounting Components
Design
Low profile
Recommended Use
Flat panel
16"
32"-120"
Max Load Weight
79.4 kg
Dimensions & Weight Details
Dimensions
Bracket - height: 48.3 cm , Wall plate - width: 70.4 cm height: 15.75 cm
84.5 cm x 5.5 cm x 26 cm / 4.5 kg
Limited warranty - 5 years
Type: Mounting kit
Brand: ErgoMounts
