The WM's wall-hugging design hangs your large flat panel display just over an inch from the wall for an extremely slim profile. Yet this TV wall mount costs about half that of competing models. Engineered to install in three easy steps, the WM is sturdy and stable.
Protect your investment
Integrated security fasteners hold display in place and deter others from removing your display -
Premium construction
It is composed of extruded aluminum and steel.
- Ergotron WM Low Profile Wall Mount - mounting kit
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall plate, fasteners, 2 brackets
- 84.5 cm x 5.5 cm x 26 cm
- Adjustments
- Tilt
- 4.5 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- From 32"
- Max Mounting Pattern Size
- 600 x 450 mm
- Max Load Weight
- 79 kg
- Mounting Stud Centers
- 16"
- Material
- Aluminium, steel
- Silver
- 5-year warranty
- 84.5 cm
- 5.5 cm
- 26 cm
- 4.5 kg
- Material
- Aluminium, steel
- Silver
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 600 x 450 mm
- 16"
- From 32"
- Adjustments
- Tilt
- Max Load Weight
- 79 kg
- Limited warranty - 5 years
