Product
ErgoMounts Ergotron Neo-Flex Widescreen Lift Stand - stand
Quicklinx: 7BM9WS00 Mfr#: 33-329-085
Type: Stand
£103.01 ex VAT
£123.61 inc VAT
Upgrade your widescreen display with five-inch (12.7 cm) height adjustment, tilt, pan and portrait-to-landscape rotation for optimum viewing. Embedded with patented motion technology, this stand enables light-touch adjustments without any knobs or levers.
Stand
Adjustments
Pan, tilt
Recommended Use
LCD display
Recommended Display Size
20"-32"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
16.3 kg
3 years warranty
AV Furniture
Stand
Recommended Use
LCD display
20"-32"
Adjustments
Pan, tilt
Max Load Weight
16.3 kg
Min Load Weight
7.3 kg
Adjustable height, rotating
Limited warranty - 3 years
Type: Stand
Brand: ErgoMounts
Price Range Ex VAT: 100 - 150
