Upgrade your widescreen display with five-inch (12.7 cm) height adjustment, tilt, pan and portrait-to-landscape rotation for optimum viewing. Embedded with patented motion technology, this stand enables light-touch adjustments without any knobs or levers.
Versatile adjustments
With lift, pan, rotation, and tilt capabilities, the Ergotron Neo-Flex stand offers flexibility. Adjust your LCD display to your preferred height, angle, and orientation for an optimized viewing experience. Whether for work or leisure, the stand's adjustability ensures your screen is always in the perfect position. -
Comprehensive compatibility
Designed to support LCD displays ranging from 20" to 32", the Ergotron Neo-Flex accommodates a wide variety of screen sizes. It includes a VESA adapter kit, ensuring compatibility with mounting interfaces of 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, and 75 x 75 mm. This broad compatibility makes it a versatile choice for virtually any desktop setup. -
Easy installation and management
The stand comes complete with cable ties and a monitor bracket, facilitating a clean and organized workspace. Landscape and portrait orientation details offer additional customization, allowing users to easily switch between modes according to their needs. The package's inclusion of essential accessories simplifies the installation process, making it straightforward to secure and manage your display.
- Ergotron Neo-Flex stand - for LCD display - black
- Product Type
- Stand - desktop
- Tilt
- 30°
- Pan
- 360°
- Lift
- 12.7cm
- Rotation
- 90°
- Adjustments
- Tilt, pan, lift, rotation
- 6.7 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 20"-32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 16.3 kg
- Black
- Package Content
- Cable ties, monitor bracket, VESA adapter kit
- 3-year warranty
- 6.7 kg
- Black
- Package Content
AV Furniture
- Stand
- Recommended Use
- LCD display
- Placing / Mounting
- Desktop
- 20"-32"
- Tilt
- 30°
- Pan
- 360°
- Lift
- 12.7cm
- Rotation
- 90°
- Adjustments
- Max Load Weight
- 16.3 kg
- Min Load Weight
- 7.3 kg
- Adjustable height, rotating
- Details
- Portrait orientation, landscape orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 58.7 cm x 32.7 cm x 19 cm / 7.5 kg
- Limited warranty - 3 years
